1 - 7 of 7 Posts
I realize my stock motor does not have a ton of HP. But, the past two trips I took to Tellico and Harlan really siappointed me. The samurai would not crawl anything. Everything had to be hit hard or conquered by sidestepping the clutch. This created a huge repair bill. Broken: front axle/ hub / transfer case mounts / tranny mount / blown winch / Transfer case output shaft.
I wonder if the change in altitude had anything to do with it?
Does anyone have any ideas on things I should check. I have not had this problem before and I am wondering where to start chasing down the problem.
General specs
Toy axles
4.89 t case
35" tires
stretched wheelbase
motor rebuilt 500 miles ago or 2 years
elec fuel pump
It happened to mine. THis past summer from wheeling in NY, then when i went to MOAB, i noticed a huge difference in power loss(to where i was slipping the clutch big time), when i got home it was all fine again. Is it noticeable where you usually drive it?
Discussion Starter #3
No the rig works great at lower altitude. I am thinking the air is thinner and it is running rich. Can this thing be re-jetted.
Jetting the carb may be too much pain if I need to do it everytime I go out of state.
i thought they had hgh altitude sensors that helped make up for that, is that possibly unpluged or busted? i have no idea im just trying to help, im an efi guy myself and i had no problems in NC
At those altitudes, I wouldn't think you would have any issue. When I get up to the 12-13,000 ft elevations, you start to see major H.P. loss. Might just have to do a basic tune-up. Maybe check your valves and adjust as needed. Have seen many power issues related to valves being out of adjustment. Even after a hard trip, I have seen them go out of adjustment. Just an idea. Have also seen where even a motor that doesn't smoke,has dirty valves. The valves don't seat properly so you basicly are losing compression and losing much power. Do a compression test.
Did it run good before? then only bad when your there wheeling, or does it run bad now too?
Discussion Starter #6
Dont know about the sensors. I will check under the hood for loose wires.
Discussion Starter #7
You may be on to something. With the valves and tune up. I would only say It ran good not great. It seems to have a slight skip you can hear in the exhaust only. I am building a Formula Toyota for 08 comps, but mid week I will be stuck waiting for parts and I will do the compression test and some repair work. We have a local comp to run in Spartanburg and I want to compete in one of my rigs.
1 - 7 of 7 Posts
