Wow lol you're redefining the kind of people that drive trucks like that :flipoff2:To be honest with you I don't really care about losing 1-2" in lift to get a safer ride.
Go for it then. Shorten the straps up about an inch and lower it 2.
WHOA! That is the wrong way to think about it bud. Untreated 4140 has a yield strength roughly 64,000 psi. That is less than a grade 5 bolt. You need to pay attention to yield strength.Much better... I actually did have the pins made out of a little higher grade metal 4140 and not heat tempered so it will be a bit more elastic. ..engineer in me wants to figure out how to make this work.
He has coilovers.Shorten the limiting straps. I would highly suggest you let the front down some. I know you probably dont want to hear that but dropping that front end 1-2" by lowering the torsion bars would do wonders for your range of motion with wheel travel.
I saw that in the pictures. For some reason it didn't register lol.WHOA! That is the wrong way to think about it bud. Untreated 4140 has a yield strength roughly 64,000 psi. That is less than a grade 5 bolt. You need to pay attention to yield strength.
Example:
Grade 5 bolt (diameters to 1") - 92,000 psi min yield, 120,000 psi min tensile.
Grade 8 bolt (diameters to 1.5") - 130,000 psi min yield, 150,000 psi min tensile.
People argue that grade 5 bolts are more elastic than grade 8 bolts. That is wrong. Grade 5 bolts have a higher plastic range so they DEFORM more than a grade 8 bolt would before breaking. As you can see, at 130,000 psi yield, the elastic range of the grade 8 bolt exceeds both the elastic and plastic (tensile) range of the grade 5 bolt making it the better choice for heavy duty applications like automotive suspensions.
This is the reason why you see grade 8 and class 10.9 (metric) fasteners on automotive suspensions.
It would be in your best interest to use heat treaded 4340 pins.
He has coilovers.
You need to remove the coilovers and cycle the suspension to ensure there is no binding and no intereference. Once you have done this AND once you have determined your max droop and compression, you need to do as Ronin said set you limit straps and bumpstops so that THEY limit your suspension movement, and no the suspension components themselves.
I wanted to do exactly as you state but the pin is tapered and didn't know if that made any different what so ever. Can anyone suggest other wise if I took the knuckle and just drilled out the taper to fit a solid both through the knuckle and bearing assembly?am I missing something, or can't the OP just drill out the knuckle and run a bolt?
This is what I was saying. Gotta be hitting when the wheel drops out in a pothole.Is the lower arm touching the knuckle at any time? sure looks close.
That would cause repeated breakage.
i really have nothing to add except holy fawk BGTL.This is what I was saying. Gotta be hitting when the wheel drops out in a pothole.
4340 or 300m heat treated along with making sure nothing is binding and prying that pin apart will get you going.WHOA! That is the wrong way to think about it bud. Untreated 4140 has a yield strength roughly 64,000 psi. That is less than a grade 5 bolt. You need to pay attention to yield strength.
Example:
something like 300m material, though that might end up being too brittle.
I talked with the machinist today and he is going to turn 4140
I found these but they are pricey.
RCV Off-Road Performance Products - CV Joints, Axle Kits, Tools
RCVs are worth the coin.
The starting point is to find out how it works and what is happening through the range of travel. If you don't already have the knowledge it would be best to start reading some suspension books and do some measuring. It isn't something that is quick and easy to spell out unless you have some basic understanding of IFS suspension geometry.I have read quite a bit about the IFS vs straight axle and I really want to make the IFS work but I just need to get some pointers on how to measure all the geometry correct.
I'd start out with:
Herb Adams - Chassis Engineering
Carrol Smith - Tune to Win
Then you need to measure all your suspension points, plot them out and see what they do. Maybe you can find a friendly alignment shop that will plot out your suspension at static and at a couple different spots through the travel.
Just keep in mind you are stuck with most of what you have unless you are willing to change mounting points.
