run your leafs upside down with some 205/60r16 tires
That's why I don't fully understand this new super low fad. It might work in some areas but I have a lot of jagged rock chunks I wheel in...not nice smooth slick rock. It really can rip a ton of stuff up on the bottom and I hate smashing my crap on stuff all the time.Something to note, if you want to be really nice and low, you will need to be well skid plated. My belly skid stretches from the rear of the front spring to the front of the rear springs, with notches for the driveshafts. I still need to do a bit more skidplating due to the oil pan being exposed, smashed the hell out of it on the last trip.
For me it the incredible stability I get from being that low is well worth it. My low height has yet to hinder me by getting caught on anything and being New England our rocks aren't smooth and slick. Does it hit? Yes. But that is what armor is for. It's a wheeling rig, its going to smash on stuff no matter what.That's why I don't fully understand this new super low fad. It might work in some areas but I have a lot of jagged rock chunks I wheel in...not nice smooth slick rock. It really can rip a ton of stuff up on the bottom and I hate smashing my crap on stuff all the time.
If you’ve never got your belly caught on anything, then you aren’t wheeling. Period. The lower your belly is the more shit you will get it hung up on. Period.My low height has yet to hinder me by getting caught on anything.
Perhaps I worded that incorrectly, I have not encountered a trail or obstacle YET that I haven't been able to do strictly because of my low belly height.If you’ve never got your belly caught on anything, then you aren’t wheeling. Period. The lower your belly is the more shit you will get it hung up on. Period.
It’s a balance; you need ground clearance without getting top heavy.
Like said above, the fad used to be tall, tall, tall, and now (or two years ago anyway) it’s low, low, low. Both are non-ideal, to really tackle obstacles you need a balanced rig.
What wheelbase are you running? I'm running 37MTR's so that might be a good comparison. Thinking maybe the belly of the rig should be at 24" with a 6" stretch.I am going to give my opinion even though he didn't ask for it.How low are you trying to go?Too low and you drag everywhere.Try to keep the belly around 22" or so.I am at 22" to lowest point on 38's.SOA on 47" chevy front springs in front and a hybrid YJ pack SOA in the rear.It often drags.I am planning on going to 42's so that should get it up where I want it.If you build wide it won't be top heavy.
That's true, there's not a whole lot of weight on the top of my rig... Adding a Big A$$ skid plate at the bottom of the frame should help too...Another thing to remember is that a tall roof doesn't necessarily mean a high center of gravity. Everything of weight on my rig is either right onto of the frame or lower. The few pieces of DOM above my head aren't going to raise my COG in comparison to the cast iron t-case between the frame rails. My jeep has always been about 2" wider than tall with all of the weight being at around the same height as the drivetrain. I have flopped it, but that was after having my driver side tire fall off the side of a 4ft ledge I was trying climb. Other than that it's been very stable.
I'm going for about 4" of suspension lift over stock, which translates into about a 2.5" - 3" drop from it's current setup. I've also raised my driveline completely above my frame so I should actually gain belly clearance.
I would agree with this. That process seems counterproductive. Although, a well thought out build and layout can grant you a low center of gravity and flat belly without raising the rest of the drivetrain higher.What I have noticed is that many people raise the drive line more and more till they have everything above the frame rails so they can get a flat belly for more clearance. Then they lower the rig down to get the "look" they want.
Ok, if it's for the look, then just say it's for the look. But don't move hundreds of pounds up higher in the rig and go through all the work to chop up the floor to make it work......and in the process making your COG worse......just to come back and lower the rig to get the COG back.
All this COG stuff is anecdotal anyway. I have yet to see anyone that actually knows for sure that raising the motor and trans 3 or 4 inches and lowering the rig 2 inches actually made the COG better.
If you raise the DT 2”, then lower the whole rig down 2”, you have effectively put the drive train back in the same spot, and lowered everything else down around it.What I have noticed is that many people raise the drive line more and more till they have everything above the frame rails so they can get a flat belly for more clearance. Then they lower the rig down to get the "look" they want.
