1 - 4 of 4 Posts
I posted this in electrical but I'm thinking I will have more luck here. Does anyone run a modified harness for a 6.0(lq4 or lq9) and the stock alternator? If so how did you wire it?
The field wire is powered by the PCM from the factory. PCM connector C2 (red 99-02, green 03-07), pin 15. I retained that circuit when I modded my harness, and then connected the 12 volt post to the battery with an 8 gauge wire.
Perfect. When my harness was modified he kept the plug for the alternator on it. So all I have to do is connect the alt to the starter if I understood you correctly.
1 - 4 of 4 Posts
