1 - 4 of 4 Posts
Will it work? I've seen the vortech heads on an older 350. I heard the lt1 heads are the same as vortechs with better flow numbers. If I use the lti intake and wiring computer etc., what will keep it from going on a older block?
i dont think that it will the lt1 heads intake and water pump are reverse flow im not sure about the blocks making a difference. but i have a lt1 trans am and im am sure about the heads intake and watre pump hope this helps you out
1 - 4 of 4 Posts
