1 - 16 of 16 Posts
Anybody have any knowledge/experience with the Maxi-Drive PTO Unit?
I've been considering it as an interesting/outrageous solution to onboard air. Of course, I'm sure it is $$$.
How a PTO unit can cost $900 AUD and two t-case gears $2000 USD is beyond me...but at a price like that it may actually be worth considering.
Wow - the prices sure shoot up when you go through an international distributor!
Thanks for the price info, much appreciated.
I bought mine through GBR for $ 599.00 and it included a Cross 40 series hydraulic pump.
The PTO fits on the end of the t-case and does not have the same issues that a set of t-case gears does. PTO is a part time unit. And yes it is worth considering.:p
Curious - any idea about air compressor options?
How does it alter driveline angles? It looks like it adds a few inches.
Any pictures of it actually installed? I'd be very curious to see that.
maxi pto
The Maxidrive pto in my Rangie is running a Thomas pto winch and works great.
There are only a few clearance issues to work out depending on you aplication.
With mine the pto actuvation lever kept hitting the floor and it difficult to refit the transfercase with a pto bolted to it as there is only around 1/2" clearance from it to the lower edge of the rear floor.
If you only want onboard air why don't you look into reworking a aircon compressor the rotory style will supply 100 psi easily and combined with a small storage tank will easily run a Rattle run or air ratchet.
Discussion Starter · #9 ·
Well, I'm investigating all possible options at the moment - this one seems somewhat novel and won't crowd up the engine bay.
Dont know how I missed this one!
Anyways, I've a M-D unit + Cross hydraulic pump for sale. Sounds like same as what Busto has.
Offers?
Offers?
Merv:
What did you end up doing for hydraulic power to your winch? I vaguely remember a discussion on it earlier in the spring.
Or, did you abandon this to focus on the Tomcat (yes, I'm envious!).:flipoff2:
Peace,
Paul
What pump?
Merv, what capacity pump is it? I'm looking for the biggest Cross version.
Strangely enough, I have seen someone do this. They didn't have room under the bonnet (4.1l FORD 6 (AUS market)), so installed a pto off the back of the T-case to run a modified AC compressor for onboard air. Worked well. had a truck air tank mounted on one of the chassis rails also.
Re: What pump?
I'ts not the biggest. It's the 1 cubic inch pump. They range from .5 cubic inch up to 1.8.
The 1 inch gives 16.4 CC / Rev.
And someone else has "started a conversion" about buying both so I have to offer him first cut at it.
PTSchram said:
Merv:
Peace,
Paul
Not abandoned. I'm changing to engine V belt driven, using the twin Vbelt idea. I'm going with a 3.9 / auto setup in the tomcat so the engine driven option is probably better.
1 - 16 of 16 Posts
