21 - 40 of 238 Posts
Discussion Starter #22
We just added the 31 spline sterling to our collection of cutters , now we can make almost anything you want for the long pinion and short pinion 10 1/4 's including Toyota conversions.
Did you get the 35 spline 30* yet? I keep hitting you up and know one day you will:) I am surprised Mac didn't call me to see if I wanted it.
Discussion Starter #25
New for August 2014
1993 and older 1.350 31 spline sterling axle yokes and flanges Part #
1350 series 130.00 $ USA FORGED 311350s
1410 series 145.00 $ USA FORGED 311410s
and various flanges
Toyota conversions 1.810 pilot 60x60 mm 10 mm holes (steel ) 125.00 31toys
oem 4.250 bolt pattern with 12x.175 thds 2” pilot ( Steel not cast) 125.00 $ 31M2
Oem 4.750 bolt pattern with 12x 1.75 thds 2.950 pilot ( Steel not cast) 145.00$ 31M3
******After market
4.750 pattern drilled ½ “ holes 3 ¾ pilot female Rockwell 2 ½ ton and 5 ton 31434
175.00 $
******Heat treated above add 100$ 31HEAT
All of these are available in 1993 and newer long pinion also *** ADD “LONG “ TO PART # FOR LATE VERSION
******** 1.375 31 SPLINE BORG WARNER T-CASES FORD AND CHEVY *****
1350 NON C/V 130.00 $ USA FORGING 130.00$ 31BORG1350
1410 NON C/V 140.00 USA FORGING 145.00 $ 31BORG1410
TOYOTA 1.810 PILOT 60X60 MM 125.00 $ 31TOYBORG
10 MM HOLES
1350 CV 2” PILOT 4.250 BOLT PATTERN DRILLED 1/2” HOLES 31BORGF
125.00 $
1410-1480 ROCKWELL FLANGE 175.00 $ 31BORGROCK
3 ¾ PILOT 4 ¾ BOLT PATTERN
Discussion Starter #30
Were going to run a couple quick sales , The first is our Dana 60 to Toyota flange on sale for 85.00.
The 2nd will be our Dana 44 to Toyota flange there on sale for 80.00.
The 3rd our 32 spline to Toyota flange in c/v and non cv patterns for 89.00.
We will run this for 5 of each then its back to normal pricing first come first serve.
Discussion Starter #33
We have a little sales tax 6.38$ and your not far so around 10$ ups. We take all major credit cards over the phone. Jess
Jess, are able to cut splines in a 9" spool? I'm tinkering with a project and would involve cutting a 9" spool to 1.64" 32 spl. Is it a possibility?
Thanks.
Discussion Starter #35
I do not have that exact cutter , we have some that are kinda close . Are you using dodge axles ? Jess
No they are meritor axles, I may have the axles cut down and resplined to 35spl, but if I could the axles as they are it'd be stronger. how close is close?
Still have this sale for the 60 to toyota? If so pm me
