1 - 20 of 25 Posts
Re-centering Hummer H1’s
Thanks to Mad Mac of C&M Performance Machine for a great product!
Why buy new centers?
A couple of BIG reasons.
1.) The stock H1 wheel lug pattern is 8X6.5.
2.) The backspacing on stock rims is insane! Recentering makes it a much more manageable 3 ½” or so.
I wanted to run these beadlocks for a long time, and when I got an opportunity to score a whole set of 4 for really cheap from a friend, I had to jump all over it.
I have a 94 Toyota Pickup bone stock, but I’m in the process of doing a SAS on it with a bit of a lift, and I really like the look and price of the used military tires that are available. For me, it beats the super spendy price of a new set of 37-38” Swampers or Pit Bulls any day.
Soo.. On to the rest of my mess making!
Here’s what I got home to waiting in my door.
Package of 4 inserts in the common Toyota and Chevy 6 lug pattern. These things had more saran wrap on them than that chick in Chinatown I saw once!
I could tell that the shipping company hadn’t treated these nicely at all, but the multiple layers of wrapping protected them VERY well from any damage!
Once I got them unwrapped, this is what I had to work with.
The only thing I didn't like was the mess of sticky machining oil left on them. Nothing a can of carb cleaner can't cure though.
Steekers too! I love me some steekers.
These things are VERY nicely made, VERY thick steel, and perfectly stamped.
I want to see what this stamping machine looks like! I bet the mold is cool too.
I really like how the outer edge is rolled like that. It makes seating and welding them a breeze.
OK, now I need to get the rims ready for them.
Here’s what I’m starting with.
As you can see from the second picture, I placed washers on some of the studs. You will soon see why.
Discussion Starter #2
Notice how I put the top ring back on as a guide? The washers hold it up a bit, and that makes guiding the plasma torch SO much easier, with no danger of cutting or getting slag on the top ring. If you don’t have a plasma, it will work just as well with an oxy-acetylene torch.
Here’s what it looks like all cut out.
As you can see, my hand wasn’t perfect, but honestly, a bit of a touchup with a grinder fixed that nicely, and I doubt it makes a difference anyway.
Now I flip the rim over and drop the ring in for a test fit.
Now, I took my grinder with a flapper disk on it to clean the paint away from the area where I’m going to weld. Very Important for a good weld.
Once that was done to all 4 Rims, I checked the fit of the rings again. They still all dropped perfectly inside the rim for a snug fit.
At first, I tried to bolt up the new center and place the rim over it on the rig to check for runout, but that didn’t work so well.
There was just enough wiggle that the rim wouldn’t stay tight on the center. So I pulled them off again, and tack welded 2 spots on each wheel to hold it together while I checked the runout. That worked perfectly.
I had between 10 and 20 thousands of runout on each rim. More than OK I think. I’ve had stock steel wheels with as much as 60 thousands of runout that I could barely feel. So, I’m happy with the numbers I got.
I got impatient, and threw a tire up to see how it looked against my truck. Looks Good! The pics don’t show how huge it is compared to the stockers on there.
Once I had checked them all for runout, it was time to weld them up. I feel its very important to take your time welding, and weld small spaces at a time to avoid warping your new center or the wheel. I went about 2 inches at a time, in 5 places around the wheel. You can weld all the way around if you choose, but I feel that my 5 welds around the edge is more than sufficient for my lightweight rig.
And that’s how you recenter a Hummer H1 Wheel Using Mad Mac’s new Centers!!
Discussion Starter #4
thhhpptthh!
this is the kind of 'poboy writeup i live to see. nice job. hummer wheels are a cakewalk to DIY but alot of people are scared of it.
but do NOT waste your $$$ on any of the .gov hummer tires (ok maybee for a pavement pounder).
think of them as polishing a d30. yeah, they MIGHT get you down the trail a little bit. but not for long. thinnest sidwalls, hardest compound, EVER.
spend the $ and buy tires.
Discussion Starter #6
my rig is my DD with 1 maybe 2 weekends a month wheelin, so thats why I love em.
If I was a trailer queen or hardcore crawler, yeah I'd prolly want something different, but for as many asphalt miles as I do, they fit the bill.
Discussion Starter #8
this setup isn't for the high dollar guys. There are better solutions out there. This setup isn't for the guy that can drop 3k on tires and not think about it. This setup isn't for the guy who has 2 or 4 rigs to play with. There is better stuff out there for that.
This setup is for the guy like me who wheels his DD or who has a dedicated wheeler and you have to save a bit out of every paycheck to get parts. This setup is for the guys who made Pirate famous. the garage fabber guy who builds his shit withwhat he has to work with. These centers and H1 rims are the IDEAL solution for guys in our same shoes. Thats why I posted this. don't be scared of running these centers and wheels. They flat out work, and the centers are serious BEEF! you won't have to worry about bending these centers or warping them or tearing them off.
This is some good stuff at a great price and easy do-ability.
I used Mad Mac centers too!
Turned out GREAT w/ about 3 1/8" backspacing...
Then a little later I added some Rock Rings and repainted them....
Nice, I did the same but with his flat centers
just a little note, might want to make it a point to wear a good respirator when grinding/cutting these wheels, the paint on them is nowhere near healthy
Yeah, I coughed up black shit for 2 days after grinding the factory "paint" off of these.
I don't know what it is, but its not normal "paint"...
It's CARC and if all you are coughing up is black shit, then count yourself lucky.
Discussion Starter #15
I didn't wear a dust mask, tho in hindsight I should have. Instead I wore one of the Uvex Bionic masks.. maybe it redirected enough airflow to keep me ok?
I dunno, I was fine, didn't have black snot or cough up any more shit than usual. Maybe being a smoker has my lungs coated in a protective layer of mucus?:grinpimp::flipoff2:
Sweet write up, I just scored a set of 4 H1 wheels myself and had been contemplating doing the re-center job my self or not. After reading this, it seems like it is not such a difficult task! Can't wait to get everything all done!
What did you use for the piece that clamps the inside of the bead? Did you get your wheels with the magnesium seal? Or did you go to PVC?
Discussion Starter #17
I got the mag runflats, just haven't gotten around to cutting them yet. When I do, I'll post up pix, and mebbe try and light off the pile of magnesium for shits n gigglz.
Couldn't get the chunks to touch off even with a torch, however cut them up outside, the dust touches off REAL GOOD:laughing:
1 - 20 of 25 Posts
