1 - 12 of 12 Posts
hello everyone
for my rig, wich has toyota land cruiser axles, i`m looking to replace the drum brakes for disc brakes (at least on the front) and have foun this kit from man a fre,
http://www.man-a-fre.com/parts_accessories/brakes.htm
does anyone have any advice about it?
is it as good as it says?
has anyone ever installed one set?
any feed back available?
thanks for your time
I had one on my 72 FJ40. Worked fantastic - stopped the truck cold. Very easy install and very solid.
But..... it still uses the old coarse spline birfields which are much smaller than the later model birfields
So I went to a disk brake axle but also thought about a minitruck conversion.
see: www.ih8mud.com (technical section) for complete writeups on disk brake conversions.
Troy
$750 :eek:
just look around ih8mud.com for the minitruck brake swap info... FAR cheaper... in fact, you could do the GM rear conversion AND the front dic conversion for less than the Man-it-ain't-free setup!
cruiserman said:
You've got a CJ7 with TLC running gear?
Anyway, the mini (hilux) disc brake conversion is a good option IMO.
yep
is a renegade 79, wiht TLC 79 axles, cases and everythign in the drive train from the LC donor
spoa conversion
bfg 35 mt
no slip lockers
chevy 350 tbi with edelbrock performer intake and carburetor
how can i upload pictures????
later
poroto
The mini truck conversion is the way to go. I did this with the knuckles and biefields of an 85 mini and used fj-60 vented rotors and 92' mini truck v6 calipers. Works great!
poroto said:
yep
Uhhh, 79 came with drums in your country???
I would have expected that they were disk..
Do the mini conversion..
I have a 1988 world market Land Cruiser catalog and it shows drum brakes were available!!!!
John H
Moderating Midget
later
poroto
You can either link them if they are hosted elsewhere using { tags or you can buy a RED STAR (see top message) or you can send them to me and I will post them for you.
[email][email protected][/email]
1 - 12 of 12 Posts
