1 - 5 of 5 Posts
Marlin Crawler, Inc.
Our 8th Annual Maintenance May has begun!!
Fix leaks and refresh your bearings and seals before the wheel'n season resumes!
10% off All Front Axle Service & Knuckle Kits
10% off All Front Axle Wheel Bearing Kits
10% off All Rear Axle Service Kits
10% off All Available Transmission Rebuild Kits
10% off Transfer Case Rebuild Kits
10% off All NINJA R&P Setup Kits
10% off All Yukon R&P Setup Kits
10% off 27 & 30-spline Front Chromoly Marfield Axles!
10% off Rear Chromoly Axles!
Discussion Starter #2
10% off Low Profile Drain Plug with steel gasket
10% off High Quality CNC Machined Spindle Nut Kit
10% off E-Locker Diff Gasket
10% off Land Cruiser Rear Differential Cover Gasket
10% off Hilux & FJ80 Knuckle Stud Kit
10% off 8mm Hub Stud Kit
Stay tuned for Week Two!
Subscribe to our Newsletter to stay updated @ MarlinCrawler.com/newsletter
Discussion Starter #3
This week we added 5 products to the sale bringing the sale count to over 70 items!
10% OFF Mechanical to Digital Vehicle Speed Sensor
10% OFF Low Profile Drain Plug with aluminum gasket
10% OFF Heavy Duty Gear Drive Shift Spring, Tacoma T/Case
10% OFF Heavy Duty Gear Drive Shift Spring, Hilux T/Case
10% OFF Heavy Duty Gear Drive Shift Spring, Land Cruiser T/Case
Stay tuned for Week Three!
Discussion Starter #4
We've added 18 locker specials including FREE Extended Warranty programs valued at $65 each!!
10% OFF all Drop-in Automatic Spartan Lockers!
FREE Extended Service upgrade ($65 value) on all High Strength Automatic Grizzly Lockers!
FREE Extended Service upgrade ($65 value) on all Air-operated and Selectable Zip Lockers!
Stay tuned for our FINAL WEEK!
Discussion Starter #5
For our final week of Maintenance May, we've added some USA-made armor to protect your maintenance investment!
10% OFF 60" weld-on Rock Sliders
Applications:
  • 1979-1995 Hilux Shortbed
  • 1984-2002 4Runners
  • 1995-2004 Tacoma Single Cab
10% OFF 70" weld-on Rock Sliders
Applications:
  • 1979-1988 Hilux Longbed
  • 1984-1988 Hilux XtraCab
10% OFF 80" weld-on Rock Sliders
Applications:
  • 1989-95 Hilux XtraCab
  • 1995+ Tacoma Access Cab
10% OFF Interior Roll Cage Kit
Applications:
  • 1979-1995 Pickup
  • 1984-1995 Pickup XtraCab
  • 1984-1996 4Runner
This takes the total to nearly 100 products on sale for only 1 more week! Click here to view the full list:
MarlinCrawler.com/Maintenance-May
1 - 5 of 5 Posts
