1 - 20 of 76 Posts
Massive 1 Ton TJ project part out & misc. TJ parts
Heres a list of parts I'd like to get rid of; More to be added in the morning; Need a good quality tow rig and trailer. Would perfer to sell everything as a package.
1998 TJ Tub and Frame: Tub has been cut for BTF Comp corners which go with it, Comes with the dash, heater assmbly, Hood, Grill, Windshield frame w/glass, and front fenders and what other parts that i have for it. Tub has been stripped of all wiring.
The frame has been stripped of all factory suspension brackets, has a BTF rear frame section tacked into place, and is setup for a 350. It comes with the rear part of the frame i chopped off if wanted. Has a clear title. $2000
GM 350 & 700r4 engine and trans. Block & trans were said to be in good stock running condition. $300 for both
Brand new Edelbrock Pro-Flo Fuel injection for Vortec style heads, Never installed, never used. This is 1 of the best fuel injection setups on the market. $2100 http://store.summitracing.com/partdetail.asp?part=edl-3507
GM Aluminum Fast Burn Vortec heads, made a few passes down the track but then removed Come with rockers, pushrods, mounting hardware, $950 http://www.jegs.com/p/GM+Performance/749898/10002/-1/10187
March Aluminum Serpentine Conversion Pullys. Brand new, never out of the box, comes with everything. $450 http://www.marchperf.com/pg66.html
New Autometer Full Sweep gauges, 3-3/8" Electric speedo & Tach, 2-1/16" Oil pressure, fuel gauge, volt meter, and Water Temp gauges $800 [img=http://img501.imageshack.us/img501/6366/screenhunter4di0.th.jpg]
Premier Power On Board Welder, with 190 amp alternator $900
Painless Wiring Full CJ wiring harness, $475 http://www.quadratec.com/products/17016_00.htm
Art Carr 700r4 Rev pattern Shifter. Needs cables $100
Hutchinson Military alloy double beadlocks, 8 lug, 8x6.5 bolt pattern, $600
79 Ford HP dana 60, stripped of brackets, easily setup for coil springs or coilovers/airshocks. Has rebuilt kingpins, good brakes, a truss, Sky high steer arms, and a set of axle shafts. Needs gears, carrier/locker. $1100
GM 14 bolt rear axle, stipped of brackets & brake lines, has a BTF 14 bolt truss, ready for 4 link, comes with Ballistic Fab lower link brackets $300 http://www.ballisticfabrication.com/Lower-axle-link-brackets_p_34-1397.html
2 16" travel 2.5 Sway-a-way coilovers, with remote resivours. Comes with dual rate kits, and springs; 2-200lb & 3-300lb. Everything is BRAND NEW!!! Never out of the box. $1100obo [img=http://img180.imageshack.us/img180/5923/screenhunter3hh5.th.jpg]
1 Hunsaker Syncro suspension seat, 1 or 2 small nicks in the fabric, has some sun fading in the fabric too $100
2 complete Rubicon Express front long arms, uppers and lowers. In good shape, jam nuts have been welded to the arms, painted dark grey. $350obo
16 Johnny Joints; 8 left & 8 right hand thread with threaded shaft, with jam nuts. These are brand new, though a few have been used for mocked up
$35 each or $550 for them all, There are not tube adapters for these joints.
A new Astro Van steering box(bolts right into the factory mounting location) Good for streching out your front axle. $100
TJ lp dana 30 Precision Gear 4.56 gears, brand new. $100
Teraflex Dana 30/Rubicon 44 high steer setup. $350 http://www.windrockoffroad.com/Catalog/pc/viewPrd.asp?idcategory=895&idproduct=3681
Alloy USA Dana 30/44 Axle tube seals, installed in a Dana 30; you remove $25
Have pics/part # for this? Very interested in this. Just wanna double check that this is for a 700R4 with a full reverse manual valve body...?
yes that is what this shifter is for, right now i dont have any pics but can take some later today.
Any pics of the beadlocks?
Which jj's are those (RE?)
Discussion Starter · #12 ·
Discussion Starter · #14 ·
Pending part # confirmation and considering that everything is included but the cable as stated, I'll take it for 100 shipped. Let me know.
I need 1 RH thread Johhny Joint if it is the 1" shank with 1 1/4" tube adapter and jam nut
Also what axle tube diameter are the mounts?
Put in line for the ram as well
Thanks
Skooter,
Just seein if the WE rims I bought have shipped out or not to give my buddy a heads up they are on the way. Let me know please.
-Chris
Master Apprentice
Ill take 1 RH JJ, let me know if you want to sell just one.
1 - 20 of 76 Posts
