Need a little help...
Ive got my mc2100 on and its running very rich. I checked the fuel pressure just before the filter and it's showing just under 7 psi. I'm currently using an OEM filter with the tank return, and an aftermarket fuel pump from the PO. I know the MC needs 4-5 psi, so do I need to plumb a regulator in? Is that the best place to read the pressure? If a reg is put in, will I need a single in/out fuel filter?
Thanks for the help!
