1 - 5 of 5 Posts
Im building a light weight buggy with toyota axles with 39s an was wondering what people a running rear engines I like the honda with the transaxle but I don't know how low geared they are if anyone has other ideas about other setups that would be great. thanks :D
Hemi
Im going to start working on one in the new year , there is some info on this site with a search..
my plans are for an ecotec and an auto
Heres what I am building currently.
All aluminum Suzuki
1.0 3 CYL (117 LBS, stripped)
Or
1.3 4 Cyl (125 LBS stripped)
5 speed Suzuki Txaxle (4.39-1 Internal ratio) Welded spiders
Toyota "Axles" (Sort of..)
Toyota 8 Inch Chunks, 4.30. factory LSD; front \ rear
64-1 crawl with 37's
I've been running a Transaxle buggy for 6 years! I think it is the clear cut "budget minded" way to go.
However, contrary to most - I run additional gearing downstream of the T-axle. This allows you to use "cheap/available" hi-way geared axles and yet achieve seriously deep gearing to help the little motor run the rocks.
Mine runs:
Mazda 1.6 engine/T-axle w/ auto and 3.83 diff gearing
NP208 (kept in 1:1) to NP241 (2.72)
3.73 geared axles.
Top practical speed is 55-60 along w/ a 220:1 Crawl.
Marv
1 - 5 of 5 Posts
