Used but in good working condition. Milwaukee Drill 4262 with variable 4203 magnetic base. 600.00
Milwaukee 4262-1 Specifications: ? Voltage: 120V ? Drill Capacity: 3/4" ? Amps: 11.5 ? No Load Speed: 350 RPM ? Tap Capacity: 1"-14 ? Drill Point Pressure: 1,630/1,670 lbs. ? Chuck or Taper: Chuck
Milwaukee 4262-1 Features: ? 3/4" capacity, 11.5 amp motor,350 RPM ? Taps up to 1"-14 threaded hole ? Dual Mount Gear Case/Reverse Mount for tight quarter drilling ? Develops up to 1670 pounds of drill point pressure with a 1" steel plate
Base 4203 The 4203 electromagnetic variable speed adjustable base features solid state electronic switching and an 11 in. drill travel. Adjustable position on this base makes lining up the bit easier and faster. Feedback speed control maintains speed and a motor/magnet lockout prevents de-mag during operation. For use on any flat ferrous material,1/2 in. and thicker.
