VT_Toy said:Don't you mean 84-95.5 body style? :flipoff2:
Body lift? David... I thought you owned a Sawsall! :flipoff2:DRM said:Well? How little body lift can I get away with to fit a 350 in an 89-94 body style truck?
Chevy 350/TH350 if it matters...
So 2" sounds about like the normal minimum to go with... I guess I can swing that.Shaker said:you can use no body lift if desired but I change the dist. to the Malloy Unilite ignition to clear the firewall. It would be best to have at least a 2 in. BL to give you room for body/frame flex.....
I wouldn't want to hack...rockota said:
Body lift? David... I thought you owned a Sawsall! :flipoff2:![]()
Well, if you are taking your time, you could just re-form your firewall around the engine... Might have to move the heater vents, but ?????DRM said:
The extra lift is probably gonna be necessary for the tires anyway... I just did not want to do more lift than necessary...rockota said:
