How bout you try reading where it says to read first before you post anything!What are the minimum required modifications for 40" tires on an 81 blazer? The intended wheel and tire is the M35A type to help with thorns. This is an offroad only truck, utility/farm use. No rock climbing or high speeds needed.
no no no! 24" of body lift, leave the suspension stock dammmmmit!24 inches of lift and 32 shock absorbers.
6" springs lift all around, don't do a body lift. I'm not going to recommend the shackle flip because IIRC it's not good for load hauling vs standard shackle design.What are the minimum required modifications for 40" tires on an 81 blazer? The intended wheel and tire is the M35A type to help with thorns. This is an offroad only truck, utility/farm use. No rock climbing or high speeds needed.
Tried the search, apparently " is an illegal character.How bout you try reading where it says to read first before you post anything! I believe it covers this exact topic.
I can post links real well. Make sure to read the first don't do.Tried the search, apparently " is an illegal character.
I guess a link would be entire too helpful.
Your question has been covered since the dawn of 4wd. You didn't read the Faq and you didn't specify what you were willing to do to fit those tires.I remember now why I stopped visiting. 2 helpful posts, 1 enthusiastic, and 5 who think running their mouths makes them cool.
Better yet try the newb section. Then come back when you have a pair of balls.Your question has been covered since the dawn of 4wd. You didn't read the Faq and you didn't specify what you were willing to do to fit those tires.
Maybe throw some better details in and get a better answer.
Written in bold on my link, This is a hardcore tech forum!
And why the hell do you need 40s for a farm truck? You will render it useless. Especially for pulling anything. Unless your farming is driving around and watching people work, then still useless.
FTFY! Was this really in the "Chevy" section?24 inches of lift and 32 chrome shock absorbers.
