1 - 10 of 10 Posts
JD Squared Model 3 Tube Bender
Tube Capacity 1/2" to 2" diameter.
RUGGED ALL STEEL CONSTRUCTION - Designed with durability and affordability in mind. All parts are 100% CNC machined. All links are machined from 1/2" thick steel and zinc phosphate plated for corrosion resistance. Fast change bending dies are CNC machined from solid steel billets and carry a lifetime guarantee against breakage. Steel dies eliminate the problems common with other manufacturers' aluminum dies, such as breakage and groove spreading when bending 4130 chromemoly tubing.
LARGE CAPACITY - Bends round tubing and pipe from 1/2" to 2" O.D. and square tubing from 1/2" to 1-1/2".
*DIE SETS SOLD SEPARATELY*
AFFORDABLE - At only $310, the Model 3 has been designed to be the ultimate in low cost bending.
EASY OPERATION - The Model 3 uses a high-ratio ratchet mechanism to allow you to bend larger tubing sizes comfortably without assistance. For example, the average operator can bend 1 3/4" x .095" wall round mild steel tubing with one hand and 1" x .065" wall tubing with ONE finger. Dies can be changed in under 30 seconds. Bend times are typically in the 30-60 second range for 1" O.D. and above tubing using the ratchet mechanism. Hydraulics may be slightly slower or faster depending on the power unit chosen.
HIGHLY ACCURATE - With the degree indicator wheel standard on every new Model 3, accurate bending is simply a matter of watching the pointer until the degree of bend you desire is reached. High contrast yellow markings on a black wheel provide excellent readability while bending.
36" TELESCOPING HANDLE - Included free with bender. The new design has twice the bearing area of the old style for longer life and provides ample leverage for tube sizes up to 1-3/4". However, if more leverage is desired for tougher to bend applications, you now can simply obtain a longer piece of standard 1" schedule 40 pipe and insert it into the ratchet lever. Comes standard with a pull pin so the handle may be retracted out of the way when not in use saving valuable floor space.
What's going on at JD2? I've been trying to order a bender and dies since May 22, emails and phone calls not returned..
Is JD2 still in business? Phone has generic answering machine and not getting emails returned?
1 - 10 of 10 Posts
