Then there’s the limiting stud and spring.
Now that we’ve opened up the flow piston, let’s go over the parts inside.
From left to right
End Cap – Has screen in the top of it to catch particles too large to pass through.
Shim/s - Just under it would be Shims if I had any. Notice the empty space between it and part number 1 and 2
Check Ball/BB – Used to seal the Orifice.
Limiting Stud – Used to keep the check system from completely compressing.
Spring – Controls actuation rate.
Piston Housing – let’s just say it holds all the bits together.
- How it works
Check ball or BB moves out of the way and allows pressure bleed off to occur. The stronger the spring the higher the pressure.
-Modifications
Remove the washers/loc-tite, crank your end cap down until flat, this will increase your pumps holding pressure to 1350~1400, which is factory maximum. Production pumps don’t come with any higher pressure flow pistons than that.
-For more pressure than stock setups
You can place washers in the bottom inside of the Piston Housing.
3mm washer – Will increase the pressure slightly (Requires limiting stud modification)
#4 Machine Washer – Pressures to around 1400 PSI plus. (Requires limiting stud modification)
2X #4 Machine Washer – pressures undocumented. A number of off-roaders user this (Requires limiting stud modification)
This is the highest pressure mod that I have read about.
(Limiting stud modification)
You will need to grind ~1/8” off of the bottom of the limiting stud after adding a washer/s in order for it to continue to function properly. If not modified you run the risk of the bypass jamming shut. That would cause a drastic spike in pressure.
The 2 x #4 machine washers are used by a number of off roaders to enable them to ram around those large tires on rock and to help boost the RAM assists.
The washers go in the bottom of the flow piston
-Summary of pressures
-Ending comments.
If you have any personal experience or modifications you have done to your pumps please share.
Thanks for reading.
From left to right
- How it works
-Modifications
Spacing | PSI | Notes |
Tall housing w/shim | 900~1000 PSI | stock |
2 shims | 1050~1100 PSI | stock |
1 shim or Loc-tite | 1100~1200 PSI | stock |
Flushed end cap | 1350~1400 PSI | stock |
+ 1 #4 machine washer | ~1400+ | Requires limiting stud modification |
+ 2 #4 machine washers | undocumented | Requires limiting stud modification |
-Ending comments.
Thanks for reading.
