1 - 17 of 17 Posts
I have been through all of the buildups that I could find that include the 404 8 lug conversions and I cant seem to find any up close pics, I am just looking for some better details, I am not sure how to mount my discs, on the outside of the hub, or the inside, so if anyone has some upclose pics of their setup I would appreciate it if you could post them up, thanks for your time.
i think it was "kabooki" on here who had some pretty detailed pics of his 8 lug conversion in his buggy build thread..i have a mog axled buggy in progress in the shop, but the axles came with the 8 lug conversion from the customer and i dont have any close up pics..it in the jeep hardcore section under "project jeepeto"
Discussion Starter · #9 ·
WOW! That is super clean 4Mogger, is that Exaxt's Kit? Looks really good, I got weps kit, not as bling, but I am sure that it will function just fine, I also got Kabuki's braces/caliper brackets, should be here any day :D
Yeah, that's EXAXT's kit. Same as I've got. I still have to do the front axle, so I can take in process, if you like. I'm really happy with their kit. Looking forward to seeing your efforts, tho!
Did you do the Pinion Conversion yet? Pics?
its Kabuki :flipoff2:
yes i should have lots of pictures in my build thread. my setup is nearly identical to the Weps kit (i believe), if that is what you have.
My centers have been turned down to fit inside 2 inch steel 8lug wheel spacers then welded all around both sides. 7 years of beating and still going. For some reason it uses metric lug pattern with superduty discs, and 4 piston toyota calipers. Id get a pic but its loaded up.
Nose to grindstone
For sale very soon (used)
Nose to grindstone
No I have tires on the rig and wont take them off for a pic right now :D These allow you to use the stock drums on a 8 lug rim. Disk brakes are going on the jeep courtesy of Kabuki. (Thanks!) A big shout out to Wepps as well for pioneering the thrifty disk brake setup (Thanks!)
1 - 17 of 17 Posts
