1 - 4 of 4 Posts
Vendor
Tear Drop Weld Washer
SKU MB2096
Pack of four only!
$2.99
The Motobilt tear drop weld washer is laser cut from 3/16" steel. Each washer features a tear drop shape to increase the surface are to weld. These washers are terrific at reinforcing holes for suspension links, frame holes, brackets, or just about any mount you can think to put them onto.
The Motobilt tear drop weld washers can also be used to repair worn, torn, oblong, stretched out holes. The fix it weld washer!
We offer these washers in many sizes to accomodate all of your needs.
Use the Drop down menu to choose from the following sizes.
Tear Drop Weld Washer laser cut from 3/16" steel. .500" hole
Tear Drop Weld Washer laser cut from 3/16" steel. .625" hole
Tear Drop Weld Washer laser cut from 3/16" steel. .750" hole
Tear Drop Weld Washer laser cut from 3/16" steel. 1.00" hole
Tear Drop Weld Washer laser cut from 3/16" steel. 14 MM hole
Sold in packs of 4!
Just $2.99 for a set of 4!
Vendor
Discussion Starter #3
SKU MB2096
Pack of four only!
$2.99
Sold in packs of 4!
1 - 4 of 4 Posts
