1 - 6 of 6 Posts
Hi guys, i'm building my own buggy using a full tube chassis, i'm wondering what kind of motor and tranny mounts you are using to avoid bellhousing cracking. I read different opinion, some are for the combo solid motor mounts and poly trans Mount, some is for the full poly set for both motor and tranny. Real life experience are very welcome. Thank you.
I use poly bushings. The main thing is keeping them the same distance apart and of the same durameter. IE either put the mounts close to the drivetrain or at the frame not one and the other.
Discussion Starter #5
How did the poly mounts work out for you? I'm getting ready to do same for mine. Thanks!
Hi, didn't have the chance to try them yet, sorry, i'm on the very beginning of the chassis, however poly bushing are done except for the brackets that i have to fabricate once i'll drop motor and trans onto the chassis, don't knowthe exact dimensions yet.
1 - 6 of 6 Posts
