Hey, I wanted to see some pics of how people mounted air tanks for their OBA. I am particularly interested in the ones that mounted them over their engine. Good? Bad?
Thanks
Thanks
The heating is a non-issue. Assuming the pressure rises enough to trigger the safety valve (which hasn't happened yet), the compressor still fills the tank from empty in less than 30 seconds.Dan84CJ7 said:My only concern with the engine compartment is that the constant changing of temperature would effect the pressure in the tank. Maybe that's a non-issue, but being uneducated in the physics/chemistry fields I decided against it.
JeepingGirlfriend said:I stuck my 2.5 gallon Kilby unit on my drivers side rear fenderwell inside the cab of the jeep.
