81 - 92 of 92 Posts
Do you mean equipment sweating or people? Cause in my old unheated shop in NC my anvil would sweat in the cooler months when there would be 30* temp swings. Some of that has to do with the humidity but I'd rather not have large temp swings in my shop in general. It's hard on things and promotes rust.
Equipment. Yeah it's the temp swings that do it.
Everything in my garage stays moisture free until you have increasing daytime temps at which point opening the doors results in every heavy piece of metal sweating from the warm air (which is why my machine shop is the basement). A well insulated shop will do this a lot more days out of the year. If you have a huge shop and are just opening a small garage door then you might get away with it but every time you change out a lot of the air in the shop and the stuff in the shop is colder than the air coming in it will sweat. You can probably get away with it if you air-condition but that's a lot of money up front and a lot of recurring cost.
What's with the recirculating hot and after and instant on heater? We currently have a has instant on that takes forever to get hot water. Would tye recirculating feature fix this?
You can't hang a beam trolley from a spancrete beam.
I'm talking just the panels, not the beams
not gonna be a hundred foot span
Always thought that was fucking gross.....I don't wanna brush my teeth where I piss.
On the other hand, I love licking my lady's butt hole all the time...
So I dunno
my sink is probably cleaner than yours
because I piss in it and therefore make the effort to rinse it out
Wow there are so many good idea's, many of which I tried...like the main floor master bedroom and others in the 1/2 story above. Did that while kids were home but now it's mostly unused. One of the best things with our house is 2 -16' greenhouses on the south basement. The entire basement has natural sunlight.
Heat goes up and cold falls. Don't try and take the AC from the basement to the top of the second floor. Put in a heat system that mostly heats the lowest areas and an AC that cool the top of the house. We have water in the basement floor. I wish the AC was in the attic.
Just having a shop is a goal for me. We used money from my shop sale to get 43 acres, so am starting over myself on the shop....(electric distribution, motors and controls) .....it's on a commercial highway, so won't be totally private.
Some shop items i used:
Shop is 50 x 84 x 14' high. White liner steel on ceiling. 1/2" OSB painted white on the walls. R24 blown Cellulose in walls, R50 in ceiling. North facing 20 x 12 and 10 x10 overheads insulated, windows in the big door so i can see what's going on. 6" slab throughout. I can drive the 21K forklift anywhere and not worry and 6" fiber over 3000 psi is plenty for a lift.
I did framed walls 2' OC and striped the outside for the steel. Makes for much better cavity to insulate. No insulation other than foam likes to be on its side for 8 to 10' stretches. Roof trusses 4' OC. Make sense with framed walls, roof perlins can then be 2 x 4's flat on top of trusses.
Used 8 5' x 3' sliding windows 8' up on the east, south, and west for natural light. Decent vinyl Low E.
When it got to -25 here last winter the coldest i saw in the shop was 38. Most of the time it stays around 43. It didn't get much above 75 in August. I keep the doors shut as much as possible. I put 2" foam on the inside of the frost walls and under the outside 4' of the floor. I I have slight regret for not doing the whole floor. At the time 2k more cost seemed like a lot. That was b4 I added everything up, not sure 2k more would have really mattered. I get a little floor sweat.
I run a dehumidifier for a bit in late spring and early summer to combat the humidity difference, again I mostly keep the doors shut. I have an opener in/on everything.
I have these lights,(they have actually bumped up the lumens since i bought) they put out great light at a good price.
https://www.menards.com/main/lighting-ceiling-fans/commercial-lights/lithonia-lighting-15000-lumen-integrated-led-2-led-high-bay-light/ibe15lmv/p-1527143387731-c-7539.htm
I have this exhaust fan, DELHI AX20-1V Exhaust Fan, 20 In, 115/230V, 1/3hp, 1700rpm CANARM. Sucks the walk door right out of your hand. Have it on a variable speed controller.
For heat I used a 250K BTU Modine. I don't keep it on all the time so forced air on demand is the only way to go for me. Probably overkill on BTU, it was hard to get a good answer going in.when the fan runs i can feel the air move in the opposite corner 90 ft away. I have a 200k also that would have done the job just fine. It heats up to 55 - 60 in no time. 2 ceiling fans help push the air back down. With the size of the building and the solid insulation I think the expanse of concrete keeps the middle at a fairly constant temp.
My .02 anyway.
And for the house, most good ideas have been said.
Scott
Wants for a mans shop!
I am in a very similar situation, our county is buying my warehouse and when I build a new one this year after I get paid it will have the following.
1, 6000 sq ft 4000 for storage rental area, boats travel trailers etc. non heated
2, 2000 sq ft finished shop all concrete with heated floor
3, Office in the with heat, shower bathroom small meeting area
4. AWESOME LIGHTING I hate shadows when working on vehicles
5, 9K bendpak vehicle hoist 4 post so I can move it around
6, lots of outlets
7, Drains in the floor
8, it will be fully plumbed for air with multiple connection points and at least 1" air lines
9, A good way to seal the heated part from the non heated part (dont have this figured out yet)
10, A decent amount of space around the shop to park vehicles when friends come over etc.
11, well insulated (I live in ND)
12, good alarm system with CCTV uploaded to the net live! Anything to keep the meth heads from stealing my stuff
13, great benches with great storage/shelving
14, nice yard/grass area around the shop!
God this is fun!
Karl
gumboot cloggeroo
6, lots of outlets
God this is fun!
Karl
What do you need 1 inch air for?
81 - 92 of 92 Posts
