1 - 8 of 8 Posts
My 63"'s I bought originally had 4 leafs plus that massive 1/2" overload. I already removed the 1/2" thick overload. Now which leaf do i remove?
I read that the good ones are only 3 leaves thick.
Also by doing this how much lift will I lose?
if we go from top to bottom
1
2
3
4
Thanks
Robert <><
I am also running these same packs and havent removed any leaves from my packs. Like Chris said remove the shortest one first and goform there.
Later
Jeff
Yeah i noticed a bunch of people running the 4 leavs with plenty of flex (especially Discos setup in the old dual shackle post) so I will probably leave all four untill I can test it all out.
Thanks.
i ran all 4 on my 82 and they worked OK, i cut the overload 1in behind the spring perch and they worked a lil better leaving the front half of the overload as a built in anti wrap bar, i pulled the 3rd leaf out, lost 1/2in of height? and gained 3-4in of travel!
Originally posted by Chris Geiger:
<STRONG>I have not worked with the Chevy springs, but have played with sevral sets of springs. Removing the shorter lower leafs seem to work best for me.</STRONG>
Chris, when i called Allpro a while back i talked to Jon about my Allpro 5" front springs and he said NOT to remove the bottom leaf!, he said to remove the second to the bottom leaf then put the short bottom one back in.
Whats up with that?? Does it really matter?, he seemed to imply that you should never remove the very bottom short leaf...??
[ 10-10-2001: Message edited by: TANKOMA ]
1 - 8 of 8 Posts
