1 - 5 of 5 Posts
My 63"'s I bought originally had 4 leafs plus that massive 1/2" overload. I already removed the 1/2" thick overload. Now which leaf do i remove?
I read that the good ones are only 3 leaves thick.
Also by doing this how much lift will I lose?
if we go from top to bottom
1
2
3
4
Thanks
Robert <><
Discussion Starter · #2 ·
I'm trying to get these things back together tonight, any ideas?
Thanks
i just pulled the overload (bottom flat one) but i think i should have pulled the next one up too. Give it a shot, you can always put it back
It doesn't matter much. Even with 4 leaves they will do work fine and still compress fine. You don't want to remove the bottom one since it has the spring clamps, so either of the two middle ones if you want to get rid of one.
Yeah Ijust looked back at some old posts and noticed 4 leafs. I saw discos dual shackle setup with the 63" with 4 leafs and would be plenty happy with that much flex.
Thanks.
1 - 5 of 5 Posts
