1 - 20 of 53 Posts
someone said we needed more RC builds even if the guy doing it really didnt know what he was doing so here goes :p I had this build going on RCC so I will catch y'all up
here is what I am starting with. it is a 1986 ramcharger with a 2" rancho kit and BFG 33" muds. I bought this to make a driver out of it and turns out everything under the black on the bottom is thin sheet metal riveted on to hide gaping rust wounds. the area around the windshield also turned out to just be gone under the upper gasket area. this was cleverly hidden with windshield adhesive but did nothing to stop the leak :eek: so a wheeler it will become.
the motor turned out to be a 10 to 1 318 with a mild cam, crane adjustable roller rockers, edelbrock performer intake, edelbrock performer carb and long tube headers.
so the plan includes a convertable top, boatsides to remove rust, dovetail front and rear and bigger axles.
Discussion Starter #2 (Edited)
first a little front axle work. I got a 8 lug 10 bolt front and a dana 44 from a 80's 3/4 ton chevy with no hubs and started to try and build one complete axle. the 44 stuff is all I could afford for now. when a cheap 60 appears I will change it. since the dodge springs are a little wider apart I cut the driver perch off and moved it 3/4 of an inch.
and now I have a complete steering axle. stay tuned for more. I only get to work on this about 4 hours every other weekend so this may take a while
Discussion Starter #3
I got my ruff stuff axle swap brackets for the 14b and did the rough cuts on the convertable project.
Discussion Starter #4
cut out the rust in the drivers floorboard that was a result of the massive windshield leak
then did a little rust removal\clearance
oh yeah the doors are gone now too. I will weld up patches in the floor asap then the rear gets lincoln locked and the front gets a lock rite and the axles go under it.
Discussion Starter #5
one lincoln locked 14b with new to me 4.10 gears told you I was cheap ;D
out with the old and in with the new
and on the the front
Discussion Starter #8
got the 3/16 plate welded on. still need to seal up the ends. gotta admit I am kinda diggin the look
Discussion Starter #9
and here we are as of today. all the materials used are what I had on hand so not everything is optimal but it is what I have to work with. let me know what you think
I like the look of the boatsides, but If you have the boat sides welded to the frame AND the body, you are most likely going to break the sheet metal at the lock pillar when it starts flexing on the trail.
Discussion Starter #12
not to worried about sheetmetal cracking but the area behind the lock pillar is the seatbelt mount and I wanted it tied to something stout. the sheetmetal can crack out above and below the slider but the seatbelts will still be attached to steel. I am also hoping that with all the tie ins and a full cage flex will be minimized. but as I stated in the first post I really am learning on this rig. this will be my first trail only build so I am sure I will make some mistakes that I can correct when the inevitable rebuild happens:D
i don't like the blocks in the rear. but other than that, it looks fun.
Discussion Starter #16
I haven't even started on the suspension yet. gonna do 52s on the front and 56s or longer depending on what I find for super cheap. you have a good point and the plan is to get rid of them asap
Cool rig and I really like the way you are using what you have on hand. More builds should be like this, a true "Grass roots" build. Nothing fancy just get the job done. Keep the updates coming.
LT.
Im hook on boatsides now:grinpimp: Gonna have to start a new project now:flipoff2:. Lookin good though.
1 - 20 of 53 Posts
