I bought the rig new in July of 1994. My first new vehicle and I was right out of college. It got a small lift and 32's and I drove it like that for 10 years and 175K miles.
Keeping stock 3 liter. Transmission is a Marlin Crawler modified 5 speed with a 5.15:1 first gear ratio. This is mated to a 4.7:1 Marlin Crawler case (3.0 V6 adapter, 4.7:1 reduction gears, 3.4 V6 adapter to the transfer case) which is mated to a transfer case from a '99 4Runner.
Axles are Mog 404's, narrowed 7 inches (primarily to center the rear diff, but also to keep overall width within reason)
Final ratio of Axles is 7.56:1. Pinions converted to Toyota, front and rear disc brakes, air actuated front and rear factory Mog lockers.
AND.....
Central Tire Inflation!!!
Hutchinson Hummer wheels (H1's) 17 X 8.5 wrapped in 40 X 13.5 Goodyear MTR's.
I have a HP 1000 Oasis Air Compressor running on 24 volts (Odyssey 2150 batteries) This runs the CTIS, lockers and Air Bag suspension. Suspension is by AiRock. Will be modifying this system to adapt to my custom 4 link.
A Howe hydraulic steering system with 8 in ram.
FJ 80 brake master cyl. to help firm up the brake pedal and handle the big rear discs.
Also have a NWOR set of headers on the way since I have to build a completely new exhaust system. The stock system was right where my front driveshaft needs to be.
now a couple of pics...
The second and third I just found from 2001..."Before" pics.
AND.....
