1 - 14 of 14 Posts
Well this is what it looked like when i got it.
Well its a 85 SR5 reg cab 4 cyl. backed buy a 5speed. Spring are 5 inch all pros with 6 inch shackles. Axles are rockwells with 41 xl's.
Discussion Starter · #2 ·
Well when i thought i could sell the rockwells and pay for the gears and lockers in the half ton stuff i put on it.
The axles are a dana hp 44 and the rear was a 9inch with 38.5 15.50 15 on wagon rims.
Well this truck is getting built on a real tite buget. The rear suspension is kind of ******* but a guy in arks. has been running the hell out of this set up for all most a year and a half. And no brakes at all. This is a trail hitch suspension or a real 3 link.
Here's one of the belly of the truck. The factory cross member set's 2 inch's lower then the hitch. The hitch is like 30inches for the ground. But I have to lift the truck another 3 inch's to clear the the front set up. pic.
One good thing about this set up is i get to point the the axle at the t-case some. Better drive line angle. The tubes weld straight to the axle tubes.
Well if i can find some gas for the torch tomorrow. I well be putting the coil bracket on and the pan hard bar to. Booger Weldz this was my first cage to build well i help toymoto build some of his.You should have see us play on the cage while it was on the ground looked like it was a jungle gym. Here a picture of Toymoto truck he got to drive it today. And all most got puled over by a cop leaving the gas staion. At dark and no lights just a truck with its haz. on. i for got he had no brakes to.:D
Discussion Starter · #12 ·
Go to the general4x4 form. And their a couple thing posted about it. i'm going to put some of my pics. there.:D I think its called trailerhitch suspension.
NotBaad said:
Looks awesome, but do you think you could start a few more posts with the word "well"? :flipoff2:
WELL.........I never noticed that:laughing: :laughing: :laughing: I wantr a real great closeup of the ball mounting system there guy.
1 - 14 of 14 Posts
