It's finally happening, I'm getting a proper shop. We recently moved from IL to IA and the deal was that I get my detached shop in the move. I had long ago out grown the single stall I used to work out of. I did most of my tube work out in the driveway due to lack of space. So this is my attempt at building my perfect shop. Due to money and zoning issues it's not going to be as big as I want but then again it never is:laughing:
I'm building a 24' x 48' stick built shop with 10' walls and radiant in-floor heat. The doors will be down the long side of the shop. One 9' x 8' and one 16' x 8' with a 36" walk out door. The end with the 9' door will have scissor trusses so I will have head clearance for a lift later. So I guess those are the high points.
They did the dirt work last night and pored the footings and frost walls today. I'm going to strip the forms tomorrow and insulate the frost walls and the excavator is coming out Sunday to back fill and compact. I can then lay the floor foam and tie off the tubing. If the weather holds out they will pore the slab Monday. The building materials show up Wednesday and I have friends coming next weekend to help me set trusses. It's going to be a whirlwind build but I have to get it up so I can get all my stuff out of storage and into the shop by the end of the month. Nothing like storage fees to motivate you
The finishing will have to wait. I need a secure weather proof box right now.
Here's the forming and poring of the frost walls. The ground slopes to the back of the lot so the front of the shop will be 2' underground. That way it looks like a normal 8' high garage from the road.
