1 - 7 of 7 Posts
heres my truck, almost ready for 4x4in. All i need is longer brake lines and a front driveshaft. Question: my tie rode rubs on my springs limiting flex so what should i do??
<IMG width=640 height=480 SRC="http://www.pirate4x4.com/ubb/uploads/toyotadre8.JPG">
<IMG width=640 height=480 SRC="http://www.pirate4x4.com/ubb/uploads/toyotadre9.JPG">
<IMG width=640 height=480 SRC="http://www.pirate4x4.com/ubb/uploads/toyotadre1.JPG">
<IMG width=640 height=480 SRC="http://www.pirate4x4.com/ubb/uploads/toyotadre2.JPG">
<IMG width=640 height=480 SRC="http://www.pirate4x4.com/ubb/uploads/toyotadre3.JPG">
<IMG width=640 height=480 SRC="http://www.pirate4x4.com/ubb/uploads/toyotadre4.JPG">
<IMG width=640 height=480 SRC="http://www.pirate4x4.com/ubb/uploads/toyotadre5.JPG">
<IMG width=640 height=480 SRC="http://www.pirate4x4.com/ubb/uploads/toyoadre6.JPG">
who made your crossover arms? It sounds like they are too low. With my All Pro arms and hi steer, I have NO problems with my tie rod hitting the springs. Do you have tie rod or heim joint ends? heims can be shimmed, but tie rod ends can't. Also, ditch the shock boots.
My Doetsch Techs can be run in either position. I'm not sure what kind of shocks those are that you have.
Hey! you live in duncan right? I see your rig all the time. I drive from Vic up to Nanaimo alot.
I also just bought Wayne Fosters Toyota!! You were at the IRC RockCreep last Sept. right?
Originally posted by dirtgreg:
<STRONG>why ditch the shockboots?</STRONG>
Because they trap any junk that gets in there against the shaft, and the shit scores the shaft, and you get leakage. <IMG SRC="smilies/eek.gif" border="0">
Plus they look <IMG SRC="smilies/rainbow.gif" border="0">
Hey guys, i got my hy-steer from OTT Industries in Vancouver, but i have rear springs up front so my axle is moved ahead about 2-3 inches. They are pro comp es3000 shocks with the F250 towers. Yeah chet i live in duncan. your new rig is nice! I just got the driveshaft in and am hopefully getting brakelines moved and a front spring taken out on each side tomorrow along with an '86 rear end with lift and u-bolt eliminators also. Im itchin for some chewin! maybe we could go to sooke on saturday?
1 - 7 of 7 Posts
