1 - 4 of 4 Posts
Posting this up for a friend of mine.
He's looking for some narrow 1 ton axles to go under his TJ. Doesn't want to go much wider then 63" WMS to WMS due to mostly running his rig on tight trails. With full widths he'll have trouble fitting down the trails.
What vechiles had 1 tons (D60, D70, 9") that are around this size?
Thanks in advance for the help.
a cc fullsize will have a 63" wms to wms. why not just get full width (67" 14 bolt) and 69" dana 60 and run some hummer h1 rims? with 7.25" of backspacing per rim youll get that width back down and get double beadlocks:grinpimp: also h1 rims are dot approved (the only beadlock to be) and cheap:D
You are not going to find a front end that comes around 63" WMS. Unless you go to a 44. 60 fronts measure around 67-69" WMS.
1 - 4 of 4 Posts
