1 - 20 of 22 Posts
Well, how did they do?
Do they have a needle bearing cap or?????
Thanks
Later <IMG SRC="smilies/jeep1.gif" border="0">
he didnt break em in the box cleanup weekend.. which for Nasvik is a feat <IMG SRC="smilies/wink.gif" border="0"> so they must do pretty well
Let me put it this way.
At one point nasvik had the tire 38sx tottaly folded under a rock and he was backing up under power.. If that didnt break them maybe hopping up on the ledge trying friday night sure would have..
They work aswome'
I met the guy who makes those at the Farmington ARCA event, and he was carrying one around that had an alloy stub shaft that was broken attached to it. The shaft just sheared right where the axle turns into the yoke. They looked strong as heck, and the fact that the axle broke before the joint says something about their strength too I think.
~Scott
did he stest the d60 ones or the d44 ones?
4x4 Consultant
These joints are Bad ass! I saw them in Nasviks TJ and they look beefy as hell. You have to run alloy shafts with them or you will just shread stock axles. I was considering them but at $300 bucks a pop no way...........dont quote me but I think thats what they cost. They are made of 300m hardened alloy .
Originally posted by UGET IT:
<STRONG>These joints are Bad ass! I saw them in Nasviks TJ and they look beefy as hell. You have to run alloy shafts with them or you will just shread stock axles. I was considering them but at $300 bucks a pop no way...........dont quote me but I think thats what they cost. They are made of 300m hardened alloy .</STRONG>
EEEKKKKK! @ 300 a pop i could care less who sells them
Thanks!
CTM RACING... 949-487-0770
Hung out and drank some brew with Jack over New Years and he said they ar $150 a piece. Combine that with the warn shafts and you'll be right at $1000 for the combo. My guess is that your front end will be as strong as a stock d60.
<img src="http://www.pirate4x4.com/tech/ctm/Image003.jpg">
I recently installed a set of CTM's into my rig. I will be taking them on their maiden test this weekend. I was hoping to go to the hammers, but it looks like I will have to settle for some high RPM snow getting it.
Here is one of the ujoints the CTM's replaced:
<img src="http://www.pirate4x4.com/tech/ctm/Image006.jpg">
A shot of one installed in the stub axle (Warn shafts)
<img src="http://www.pirate4x4.com/tech/ctm/Image010.jpg">
These ujoints are the nicest quality ujoints I've ever seen. So far to date, one has NOT been broken.
1 - 20 of 22 Posts
