one hell of a 1 day build
The biggest difference I've noticed is that it doesn't HOP and bounce nearly as much when you are trying to get up difficult stuff. The tires generally just spin smoothly when they loose traction and gain it again smoothly too instead of all that spring wrap loading and unloading.The big question I have is do links really make that much difference in performance in the rocks?
Totally agree with Eric, links almost eliminate wheel hop. Links can allow more articulation in certain situations but it looks like your spring set up allows plenty of flex and articulation.Thanks Erik. I've read that links help with HOP. I've heard that people that go to links wouldn't go back but as for wrap why wouldn't a traction bar produce the same results. I'm guessing that the rigidity of the links helps keep the axle better located. Whereas the leaf spring is flexing and allowing the axle to move but not necessarily wrap with a traction bar. It seems subtle but could be the difference.
I'm going to drop the fuel tank this weekend and take some measurements.
I guess I never thought of trying to sell it. I was planning on using the main hoop and the top but I don't really have a great use for the front clip. It is in sections now but you could probably join the front and the top back together and probably even join the sliders that I still have to cut off to mate up with the rest. The back is a loss but I do have a stout rear bumper that would mate up to a stock runner. I don't know make me an offer. I can get pictures of the parts if you want them.Do you want to sell the old exo if you are not going to use it?
