I have the 5.0 running and everything is going great, however, I need a wire that is hot in run only. To see if the thing would run, i hooked it up in hot all the time, and it started, but wouldnt' shut off when I turned the key to off.
I know of one hot in run wire, which is the asd relay wire from the TJ. Problem is that I bypassed that relay about 2 years ago, and dont' really have it anymore.
How can I get a wire that is hot in run only? Or, is there a way I can use a relay to acieve this?
The starter soleniod has the ignition switch wire too it, and I was debating on whether I could wire that into a relay so it would be hot in run only
Thanks
Josh
Thanks
Josh
