1 - 5 of 5 Posts
We are trying to get my sas finished up on my Tacoma and we can't get the hubs to go on. It is a HP 44 out of a 79 F-250. I am using Warn standard hubs. They go on all buy the last 1/4", and it looks like they are bottoming out on the spindle. Does anyone have any tricks or help on this?
Thanks.
Where did you put the axle snapring. Outside of the inner hub piece or inside of it. It goes on the outside and if its inside it will keep the hub from going on all the way like you are describing.
Paul.
Im talking about the small snapring that goes on the axle shaft not the large ring that holds the internal hub piece to the hub assy. Fords usually have the small snapring behind the factory hub assy. If you leave it there it will not let the warn hub bottom out far enough in to allow you to install the outer large ring.
Are you sure that the axle shaft is far enough into the spindle?
Paul
1 - 5 of 5 Posts
