1 - 3 of 3 Posts
I have lost headlights on my 83 toyota truck the fuse is good and the lights will burn when i use a toggle switch. Does anyone know if they have a fuseable link or a relay to the headlights and if so were is it located?
Could be the relay, could be the dash switch (could be a lot of things, but that's where I'd look first). Sorry, I don't know where the relay is on your truck.
Listen for the relay clicking. If not, check for voltage at the coil when the switch is on. If fine, run a temp line directly to lights from relay.
1 - 3 of 3 Posts
