1 - 20 of 26 Posts
hey guys im looking to swap a fj80 front axle under my mini. i need everything hub to hub, perferably no e-locker and no ABS. thanks guys
--calvin
where are you located? I can think of one that might still be available in the Portland OR area
tchcalvin said:
im in lubbock, tx but i am willing to have it shipped in if the price is right
i just had one shipped fedex ground for $41
I'll try and get a # for you to call. The guy that had it is in Moab for the EJS so you'll have to wait till he gets back.
Have you decided how you are gonna connect the drag link?
I have seen 2 of these on mini's and the drag link suxed on both, they had to use z shaped and it really looked cheesy.
Butch
tchcalvin said:
im gonna have full hydro so no drag link!
OK.....you know these are under the axle type steering and there is currently no option for hi steer arms for this axle?
--calvin
Why not ABS, you just plug the hole, or use it to make an arm that will mount 3 ways.
Why not the E-locker?
Discussion Starter #14
ya i know this but OTT sells theirs for 550 and knuckle machining and i am thinking about home brewing something. cary at gotpropane.com did the same swap and i was thinking about copying his work.
Discussion Starter #15
abs-- ?????? i just figured it would be easier
e-locker--- i have a lock rite layin around and i think that it will be ok.
Are you positive? I thought i heard they stopped making/selling those. Hopefully i am wrong! Link?
Discussion Starter #17
it is still on their web site and i also talked with sleeoffroad and they said "i can make no promises, but we are working on some" so, i cant do the crossover i thought about getting a tie rod from bud built and once it is sleaved it will be like 3/8" thick and 1.50" od soooo........ that might be an option.
Discussion Starter #18
i think i may do a coustom diamon axle, it may be easier and cheeper in the long run, just swap some of my old mini parts into it.
Discount!
$41 to ship an axle? Carparts.com carries fj80 complete axles? Are you out of your mind.........! Are you on weed?
OTT stop making theirs, I talked to them back in early Feduary.
I hope Slee Offroad would make some, I live about 10 minutes away from them.
1 - 20 of 26 Posts
