finnished plumbing in the full hydro, problem...
it steers left to right as it should, no bubbles in fluid. the problem. Steering feels really heavy, slow and kinda sticky. Pretty much undriveable.
pump is not making any strange noises, etc. Was thoroughly bled on jack stands.system steers fine when engine is off, on stands, turns left to right just fine.
system is stock GM pump(99 4.3) charlynn orbital. (#201-1021-005) lines from orbital to ram are 1/2 ID.
small tranny cooler as steering cooler, rockstomper resevoir, with top output capped run into top of chevy resevoir.
return side of system leaves orbital, runs through cooler, back to return on factory pump. using-6 hose/fittings.
