hey guys , I need some help right away if you can....... let me give you a little back ground first. I bought a 75 dodge D100 for my daily driver, and whover owned it before me stripped the nut holding the hub on the axle, which resulted in a nasty break of the hub while i was on the road...... thank god I was not on the freeway and only going 5 miles an hour when the hub seperated...... seeing as how I have no free time now i had the truck towed to the local shop, Now I am thinking of swapping in another front axle, I want to find something that does not have the bad wheel bearing design that was used from something like 74-79 but i do not know what year axle to look for that will make an easy swap..... the dodge is equiped with a 318, 727 3 speed and np205 tranfer case... minus the front drive shaft .... any help or advice would be much appericated....
