1 - 13 of 13 Posts
I was trying to losen the zerk fitting to bleed my clutch (stock trans) and it snapped right off. What is the easiest way to fix this?
Anyone else do this before?
Any help is appreciated!
Steve
Get a square shaped e-z out from Sears. Hammer it into the opening of the bleeder screw and try and get it out by turning it counter clockwise. I have tried the threaded e-z outs and they didn't work like the square ones.
If you can't remove it with a easy out on the vehicle you'll have to take it off and put it in a vise. Try tapping on it with a hammer, sometimes that will break it free.
Good luck
I would have to flush the trans you say?
I forgot all about easy outs!!
Thanks guys... <IMG SRC="smilies/beer.gif" border="0"> <IMG SRC="smilies/beer.gif" border="0">
Discussion Starter · #9 ·
How much do the slave units run? I have been looking around a couple places, but couldn't even find them...
A good set of easy outs is a must have for any garage. The set will tell you what size hole you need for each size easy out. You should get a left handed drill bit for each size necessary. Drill the center of the fitting with the correct size Left Hand bit, as you drill apply pressure in small bursts this can cause the bit to bite the material and break the threads free. A left hand bit will many times retract the broken bolt with out the need of the easy out.
Josh
Discussion Starter · #13 ·
thanks for all your help guys <IMG SRC="smilies/beer.gif" border="0">
I am gonna pick up some easy outs (and the left hand bits)tomorrow.
Such a stupid little thing is keeping my Jeep off the road. What a pain!
1 - 13 of 13 Posts
