1 - 3 of 3 Posts
I am installing a 3 phase 240 volt starter with a 240 volt coil and am confused on the wiring for the coil. Anyone got a simple explanation of it? The more I read the more conflicting the information it seems. Thanks in advance
Jake
gumboot cloggeroo
_irate4x4 com
what voltage does the coil have stamped on it?
Edit: Sorry, I guess the coil is obviously stamped "240 VAC"
Just need any two hots to get 240 for the coil. Are you wiring the control wiring from scratch? Pics?
What "conflicting" info have you read?
240 coil wires the same as a 120 coil with the exception both wires are hot, no neutral
any coil will be single phase as in only 2 wires going to it
using a 240 coil avoids having a 120 transformer in the 240 volt only enclosure
without more info it's hard to give you specifics
what are you wiring?
1 - 3 of 3 Posts
