I just regeared my truck and now the rearend is making a wierd noise. I purchased the entire third member from Randy's R&P, with a detriot and 5.29 yukon gears. My problem is that the rearend whines when I let off the gas to shift or let the truck coast to a stop. At first I thought the gears might be damaged, but it only makes the noise when I let off the throttle. Has anyone had any similar problems? The diff is full of new fluid, the tires have the same tire pressure, and I was breaking in the gears in the same way that Randy's R&P recommended. Any one have any ideas?
