Hello all need some help on my build. Got a 1966 Jeep Gladiator that's all original and is getting changed. The end result is more speed on the highway and reliability. The stock 327 AMC engine has to go and will be replaced with a Chevy 350. I have a T18 trans with a Dana 20 T case in it. The rear end is a Dana 44 and going off the manual it could either have a 3.92:1 or 4.27:1 gearing. I have 33's on the truck now and if I recall was only able to get 65 mph almost running 5000 RPMs. Way to high, don't like running my engine that high for too long. I'm open to many ideas to changing this. I've read many post about this issue and got different results. Some either used a Saturn overdrive on their Dana 18, Most changed their axle gearing to help. I know I will have to change my gearing eventually but an overdrive may help a lot. How to do it, a NV4500 trans with a Dana 300 swap or should I just change to a Dana 18 and use the Saturn overdrive. If I do a D 18 then I have to change the rear axle all together. Very confused on what to do, any help would be appreciated. Thanks
