1 - 7 of 7 Posts
Hey I need some advice on tubing benders. I know almost exactly nothing about them and don't have a ton of cash. What I have is a 25 ton hydraulic press. Does anyone make a set of dies that can be used in a standard press? If not have any of you modified a set to do this? I need to get tools rounded up before winter so that I can get my cage built while work is slow. Thanks for any help!
I just need to bend a cage for my truck and maybe some bumpers. Crap like that. I don't have $1000 bux to spend on this and couldn't justify spending it if I did. Anyway, you think manual bending would be cheaper and easier? How bout that Harbor freight crap? Anybody used these? They are pretty cheap if they would work even for 1 job I would be happy. Anyway thanks for the help!
Fabster
I used the JD2 model 3 tubing bender. its about 500 for the bender and a die. check them out at JD2.com
If you do a search on tube benders you will find out a lot of info on this subject. I my self am getting the jd2 model three.
1 - 7 of 7 Posts
