1 - 11 of 11 Posts
Who has an '87 wrangler I can look at? Or more precisely a Dana 35 non C-Clip axle?
I need to look at one to figure out the following things:
1. I need the brake line T-Connector. Or at least to see what it looks like. Is it part of the main hose? Does the main hose hook into it? On my '93, the axle vent comes off the t-connector. On the '87, there is a seperate axle vent, and then a bolt that I assume holds the t-connector in place. None of the auto parts stores can find this part. I might be able to find a similiar connector, but first I have to figure out what the stock one is like.
2. I need to see the cylinders in the rear drums, which way the brake lines screw into them...they're different, and I'm not sure what side goes where.
That's it for now, but it's the only thing holding me back from finishing this "small" direct swap. Ebrake is my next thing to look at.
I'll have pictures to better explain what I'm talking about tomorrow.
Thanks for any help! Even if you know where an '87 is sitting on a lot for sale...I just need to see one!!
Thanks! I also have to figure out how to take the pads out of the front caliper...I think I need a 7mm allen wrench.
Pictures of the T-Connector or where the brake lines connect to the drum would be wonderful!
Hey Dan, mines an 88 but I think these pics show what you are looking for.
The connector is part of the mail brake line.
<IMG width=640 height=480 SRC="http://www.pirate4x4.com/ubb/uploads/brake2.jpg">
Bleeder is on top and the brake line is below.
<IMG width=640 height=480 SRC="http://www.pirate4x4.com/ubb/uploads/brake4.jpg">
[ 09-06-2001: Message edited by: Thumper ]
This one is from a 89 I think. I swapped it into my 92 but I guess I was lucky and got all the brake stuff with the swap. I used what worked between the two axles. You will have problems with your original ebrake stuff. You will need the ebrake from the 87 axle if it's the same as mine the original will be too short.<IMG width=500 height=375 SRC="http://www.pirate4x4.com/ubb/uploads/braket.jpg">
[ 09-06-2001: Message edited by: 4BANGERYJ ]
Thanks, that's great! I found the main hose at a "real" parts store. Autozone, O'Reilly's, and the dealer couldn't get it...but my local small parts store will have it by 2pm today.
Thanks again!
Now I just have to hope that that new main brake line will connect to my main line coming to the back to that bracket!
Hey Thumper, or whomever else. How is your brake line run across the axle? Over the diff, in front of the diff, behind the diff?
Thanks! I can't really figure out how they're supposed to be run from just playing with them...
I would run the brake line UNDER the diff. That way it protects the flimsy housing from any rock hits. <IMG SRC="smilies/idea.gif" border="0"> <IMG SRC="smilies/laughing.gif" border="0">
<IMG SRC="smilies/laughing.gif" border="0"> <IMG SRC="smilies/laughing.gif" border="0"> <IMG SRC="smilies/laughing.gif" border="0"> <IMG SRC="smilies/laughing.gif" border="0"> <IMG SRC="smilies/laughing.gif" border="0"> what a bummer!!! Dana 35's suck!
Discussion Starter · #9 ·
I hear ya, they do suck!! But at least this one isn't a c-clipped version.
If I had the $$, it'd be a 60 going in there instead of a 35. Maybe when I'm out of school and have a real job!!
Originally posted by Robert:
<STRONG>I would run the brake line UNDER the diff. That way it protects the flimsy housing from any rock hits. <IMG SRC="smilies/idea.gif" border="0"> <IMG SRC="smilies/laughing.gif" border="0"></STRONG>
do that and add some ip ties itll be a good truss
Originally posted by brimy311:
<STRONG> <IMG SRC="smilies/laughing.gif" border="0"> <IMG SRC="smilies/laughing.gif" border="0"> <IMG SRC="smilies/laughing.gif" border="0"> <IMG SRC="smilies/laughing.gif" border="0"> <IMG SRC="smilies/laughing.gif" border="0"> what a bummer!!! Dana 35's suck!</STRONG>
you know what is funny is evry one says that d-35's suck but the d-30 is a strong axle. I have broken 4 front axles on my d-30 but never have I hurt my d-35. Although I did screw up my lockright so I fond an 87 with no c-clips and a detroit so I swapped it for my 95. I have not repaired an axle for over a year now. <IMG SRC="smilies/biggrin.gif" border="0">
1 - 11 of 11 Posts
