1 - 17 of 17 Posts
4 hummer rims with run flats
and a cheap set of 42s for a 16.5 rim
thanks
kyle
241C transfer
Try Pick-n-pull here in Sparks, Nv. I was wandering thru the other day and counted (four) Np241's laying on the ground, (without cracked cases, no less). Price for a transfer case regardless of make is right around a 100.00 bill, plus core charge if you dont have anything to turn in. I believe the core charge is somewhere around 30.00
HTH,
MIke
Reno Nv
thanks for the info iwas going to try our local pick n pull
kyle
I will have a 241 pass drop with a 32 spline input up for sale soon. Also comes with clocking ring and shifter. I might beable to get it out this weekend if you are interested.
i need drivers drop iv got a 208 pass drop now
Get a Dodge 241 (only came driver's drop) and swap the input gear. One off a diesel with NV241 DHD is supposed to be strongest. The one I just sold {I hope} even had the PTO port on it.
i have a ps drop 241 with the 32 spline gear. it's fairly simple to exchange the inputs so if you can get a driver drop 241 you can always swap the inputs. the driver drop 241 is a lot more common than the ps drop.
i can help you with the conversion if it comes down to it.
Discussion Starter · #14 ·
im not looking to spend alot of money as an atlas is in the future
Discussion Starter · #17 ·
42s or bigger and hummer rims needed
1 - 17 of 17 Posts
