1 - 10 of 10 Posts
I'm starting my first build this summer, I have a 73 CJ5 to start with, but I don't plan on it being anything like what it is now at the end of the summer. This website is exactly the type of place I want to get my information from. I have been trying to learn about the different types of transfer cases and options ie stacking them, changing gears out, etc. but I can't seem to find a real good source that covers it all. Is there something like a TOTM about T-cases? BTW I'm swapping in a 350 and planning on using a SM465 Tranny. Any ideas or suggestions would be appreciated as well...
thanks
In a CJ5?Better plan on streching it.I would run an np231 to a dana 300.But then again it will be alot of coin to get all that setup and functional.Why not run a 4to1 dana 300?Or I would look at a stak 3speed case or the atlas 4 speed if you need all the different ratios.
CJ5s are not long enough for what you have planned. especially not the earlier ones like yours. you probably have the dana 20 already, which has the texas bolt pattern. either way you look at it, you will have to use adapter plates behind the 350/SM465 which shortens your rear drive shaft. you could build up your 20, its not a bad case, just not as hefty as a dana 300 [round bolt pattern].
Discussion Starter #6
Thanks for all the replies, I know that the wheelbase is an issue and I have already planned to try and lengthen it. I want to figure out what all needs to go under it before I do that though so that way I don't end up doing work twice. Besides that I'm taking it down to the frame first thing this summer so it'd be nice to do a lot of this work while I have that done.
Anyone know what the cost of dana 300 should be? Also, where would be a good place to pick one up? I've checked craigslist....
Thanks
Craiglist is a great place.I was/am selling a dana 300 but I am waiting for the payment.For reference I sell Dana 300s for 200$ plus shipping.If you could pick 1 up for 100$ I would say thats a good deal.I must say thats alot of work to do to an older CJ5.It may not be the best bet.You may be better with a CJ7 just for the legnth of your drivetrain choice.That may not be an option as you have the CJ5 already but for for what you want it may be more cost effective.Thats just my 2cents Good Luck
Discussion Starter #8
Okay I've been checking Craigslist pretty regularly. Hopefully a deal pops up on there soon. I know the CJ5 is not the best starting point (I'm figuring that out more every day) but I have it to work with already and I can sell the parts off that to make some of my money back. The jeep was bought brand new by my grandfather in 73. He drove it, my dad had it for 15 years and now I plan on doing it. I'm not much for mushy sentimental stuff, but I'd like to use the cj5.
Thanks for the input though.
I don't know how you're going to use your vehicle but the 5 may not be the best candidate for a major makeover. For mild crawling and trailriding upgrading the stock components usually works best and cheapest and least hassle. For example, the frame needs to be boxed. If it has a 232, plug in a 258. Put 3.15 gears in the transfer case. Swap in a Ford T18. Tru Tracs front and rear (Detroit is a mite twitchy in a SWB). Visit Novak Adapters website to answer all your questions.
Discussion Starter #10 (Edited)
My initial thought was to just restore, but the 304 needs a rebuild and the t-15 needs to be replaced. I looked into rebuild kits and new gears, bearings, etc. and it's just as expensive to upgrade than it is to repair. I don't plan on this thing being able to win competitions or even compete really for a long time. I'm in college, on a somewhat tight budget and just wanted to do this as a hobby. I understand everyone's concerns about the cj5 not being the best start but it's what I have and I'm not on an unlimited budget to afford something else. Not being afraid of a challenge and a lot of work, eventually I will make it happen.
I just needed help with the Xcase and as of right now I am liking the dana 300. Thanks for everyone's help
1 - 10 of 10 Posts
