41 - 60 of 254 Posts
Discussion Starter · #41 ·
Decided i want to go with the Twisted Customs Grand Cherokee hood. I was going to make my own out of ZJ skins....again. but when i factor junk yard sheet metal and my time buying a hood is so much better.
Discussion Starter · #42 ·
Got a cash course on the lathe today. Last time I touch one I was 12.
Got one of these done today. After a test fit I'm going to make 3 moar.
Discussion Starter · #43 ·
Made the remaining 3 so I can do all my upper link mounts.
Fuck I love machines!
Tomorrow I'm going to model the tcase adapter. Will be nice to get that cut on the cnc this week.
Discussion Starter · #44 ·
Welded in the upper ca bushings
And got the upper skid plates done 1/2" uhmw.
Discussion Starter · #46 ·
1/8"
Discussion Starter · #47 ·
Again, moar from today.
Belly is braced and the suspension gussets are capped.
I left them open with the triangle holes to allow dirt and crap to be washed out. With the dimpled holes I know crap will get in there.
And now for the bracing
http://img.photobucket.com/albums/v280/Kraqa/510938c2.jpg[/IMG
[IMG]http://img.photobucket.com/albums/v280/Kraqa/244da39c.jpg
that's a deeeep belly.
I dig the chassis design.
Discussion Starter · #51 ·
the belly is only 11" deep. same as my current chassis. but my seats sit 3/4" lower in this chassis then my current one.
i was able to meet the roof clearance spec and get a 74" roof height with a 20" belly.
Discussion Starter · #52 ·
1/3rd of the LED lights showed up.
8 os the 2" single LED's and 2 of the 32" light bars!
i'm hoping the 42" bar shows up monday....and the 4 22" bars show up in about a week.
Discussion Starter · #54 ·
Ya I lite then up. They are bright as fawk!
Wish they came in a euro beam but they don’t either spot of flood.
Discussion Starter · #55 ·
well....i'm gonna save some coin here. should go out on the CNC tomorrow night.
TH400 to Atlas adapter. will be making them from T6061 aluminum. i have the plans for one with a VSS in it but i think those will get heat treaded since they will be about 2" longer.
right now this is 1.5" long.
Discussion Starter · #56 ·
here is some more progress, belly side skid plate mounts are done.
Pretty rad you can make your own adapters now. Can't wait to see what you do with the new machine
Discussion Starter · #58 ·
aight...here sone cool shit. or at least i think.
Big Country Customs called. the hood was in. thanks guys!
support squared and plumbed for the cowl bar....
test fit
under hood cage hoop mocked up....
Fitting thw hood with the cage work
a view from the drivers seat...about 3" more inch of vision
Discussion Starter · #59 ·
the old buggy next to it. hard to beleive that with the same belly clearance the hood, cowl and roof will be 3" lower then the old one.
Discussion Starter · #60 ·
gonna get soem tube rolled.
This is my current idea of the arm bars, rear half and roof lines. probably not so much of a rake on the a pillar though.
