1 - 6 of 6 Posts
Just arrive down here my new springs; QA1 14", 150lbft.
What is the best way to "bolt" the springs to spring plates? I saw two ways, one is using a small U bolts upsidedown and other bolting a bar over lower and upper coil.
Wow dude not to sure. Why not ship them over to me and I can make some custom holders for you??? :flipoff2:
i made a big washer type plate with a smaller spacer the size of the id of the coil and just under the thickness of the coil welded em together , and drilled a hole to put a bolt through it.
its sounds way more complex than what it is i'll see if i have any photo's.
limit straps run through the center
Or do both like Zukiboy did. Ubolts on the bottom and bar clamp over the upper coil wrap to secure the top
1 - 6 of 6 Posts
