1 - 1 of 2 Posts
Administrator
NEW COMPACT HEATER REVOLUTIONIZES OFF-ROADING
Posted on 02.14.10 by Lance
Filed under Press Releases[, and Tagged With:
Chilly and cold, winter days just got more comfortable for off-road enthusiasts. From Aqua-Hot Heating Systems, the leader in hydronic heating systems for the RV industry for over 25 years, comes the innovative Aqua-Hot 100 Off-Road Heater. Connecting to an engine's cooling system, the compact unit quietly and efficiently heats cabs with a brushless, radial axial fan.
It's perfect for two-person UTV cabs, small utility tractor enclosures, supplemental rear heat in Jeeps and larger vehicles where battery power is limited. The economical Aqua-Hot 100 draws less than 0.5 amps, ensuring long hours of warmth without draining the battery. Delivering big heat from a small package, it weighs only 3.5 lbs. and measures just 5.5" H x 5.5" D x 9.5" W. A tough, high-strength nylon 6/6 housing resists harsh elements and challenging environments.
An adjustable mounting bracket rotates 180° for easy installation to the floor, firewall or under dash. Slotted mounting arms and a serrated clamp ensure a tight fit. An integrated, variable-speed switch reduces wiring and enables the fan to be set from 0 to 100 cfm.With a one-year warranty, the versatile Aqua-Hot 100 Off-Road Heater has a suggested retail price of just $189.99. For larger cabins where more battery power is available, the Aqua-Hot 200 provides a fan output of 0 to 200 cfm and draws just 2 amps. Convenient installation kits are also offered.
Contact
15549 E Hwy 52,
Fort Lupton, CO 80621.
Toll free: 800-685-4298 or 303-659-8221; Fax: 303-857-9000; www.aquahotoffroad.com.
1 - 1 of 2 Posts
